[4th Gen : 01-07]: 2004 Dodge Grand Caravan shaking issues
Old May 2, 2014 | 02:56 PM
Mseymour72's Avatar
Mseymour72
Default 2004 Dodge Grand Caravan shaking issues
I recently got stuck with my van, and I had no severe shaking beforehand. But now my van shakes quite a bit at around 60mph. I had to get pulled out by another vehicle and my first guess is it could be my leaf spring on the passenger rear, because thats what was pulled on. But I do not even begin to know how to check or if it is even a reasonable thought to believe my leaf spring is the cause of the shaking. I checked my tierods on the from passenger tire, and I believe they are fine. There is however a little play shaking the tire left to right.
I was wondering if anyone would know where to start with this issue. I also recently got my tires balance so there isnt an issue there, And it seems like my van now has a tendency to pull to the right.
Any help would be greatly appreciated.
Side note, I have a 2000 caravan that I recently acquired for parts. Wondering if I should have to worry if any of the parts would not be interchangeable.
Old May 27, 2018 | 03:49 PM
zerorisers's Avatar
zerorisers
It sounds like a hub bearing issue with the play on your wheel. I would suggest replacing the hub bearing, having to do the same on my 2000 grand caravan.
