2000 Dodge Caravan Power Window Problem
Old Jun 2, 2014 | 02:01 AM
Vikingtu's Avatar
Vikingtu
Default 2000 Dodge Caravan Power Window Problem
I have a 2000 Dodge Caravan SE and the drivers power window works find going down but when I try to put it up it will move up an inch and I have to wait a few moments. I then hit the up button again and it will move up a little again. This process takes me 5 to 10 minutes to get the window up.
Anyone know what the problem with this window is?
Thanks...
Old Jun 2, 2014 | 08:04 AM
Moving to the correct section.
Old Jun 2, 2014 | 03:41 PM
Cougar41's Avatar
Cougar41
Sounds like the thermistor circuit breaker (PTC) in the motor is opening due to overheating. It cools then closes again. Probably a bad window motor. You can replace the whole window regulator assembly, just the motor on the assembly or just clean or replace the brushes in the motor - the usual culprit for your symptom. Make sure the window side tracks are cleaned up.
Old Jun 2, 2014 | 05:58 PM
Vikingtu's Avatar
Vikingtu
Thanks Cougar!
