2003 Caravan Caliper Bolts - what size ?
Old Oct 18, 2005 | 03:32 PM
mgordonb's Avatar
mgordonb
Default 2003 Caravan Caliper Bolts - what size ?
I must replace all pads on a 4 wheel disc 2003 Caravan Sport.
I can't see the van until I go over to do the job.
Does anyone know if the calipers are mounted with bolts or hex bolts?
If I need a hex, I'd like to buy the right size when I buy the pads tonight.
Thanks
Old Oct 19, 2005 | 01:12 AM
brandoncrone's Avatar
brandoncrone
Default RE: 2003 Caravan Caliper Bolts - what size ?
The front calipers are held on with 7mm allen bolts, and the caliper bracket-steering knuckle bolts are 13/16
Old Oct 19, 2005 | 11:30 AM
mgordonb's Avatar
mgordonb
THANKS !
Old Oct 19, 2005 | 05:54 PM
wireman's Avatar
wireman
My 01 Sport were held on by a 12mm bolt removed with a socket.
Old Oct 19, 2005 | 06:29 PM
mgordonb's Avatar
mgordonb
Hmmm. Thanks again. Any bolts won't be a problem since I have hundreds of sockets. I also have 7mm & 9mm allen bits for a 3/8" drive. I should be in good shape.
I appreciate all the input.
Update after the job - On the 2003's (with 16" wheels) all four calipers are mounted with (2) 7mm Allen Bolts. I didn't need to take the steering knuckles off. Rotors were okay so each wheel took 15 minutes tops.
