[5th Gen : 08+]: 2011 grand caravan Map light assembly removal?
Old Jun 22, 2014 | 01:22 AM
Fastprepflop's Avatar
Fastprepflop
There's no re-wiring needed.
I removed the shield and it was a mission to remove the old bulbs because the holders are so tight.
To reinstall the new bulbs was also a mission, there's barely any room to maneuver your fingers to attach the bulbs to the holders, I used a flat screwdriver to pop in the one side of the bulb and then the other side. You'll need a lot of patients and you'll get it.
I bought the bulbs from a local store, they are the same as your dome lights bulbs.
Hope this helped,
Tnx.
Old Jun 22, 2014 | 09:47 AM
DodgeCaravan2010SXT's Avatar
DodgeCaravan2010SXT
question did you get the can bus one led or the 9 led? I have 2010 list as both and confused which one to order?
Old Jun 23, 2014 | 03:37 PM
Fastprepflop
The map lights have 4 LED and the dome and rear hatch are 8 LED.
I got them from a local store in Toronto.
Some japanes bulbs.
Tnx.
