2008 Gr. Caravan Ignition problems
Old Jul 7, 2014 | 11:00 AM
gordyk's Avatar
gordyk
Default 2008 Gr. Caravan Ignition problems
GordykCANADA. I have a 2008 Dodge Gr.Caravan. WIN does not seem to recognise there is a key in place. Vehicle will not start (or crank over) and even in the ACC postion the radio doesn't work nor do the power windows. Everything seems to work okay from Key FOB (I have 3 of them) I can even initiate Auto Start from the key FOB, lights flash, engine starts okay. I get in the vehical, put the key in WIN and nothing happens.
Can't pull gear shift out of park position. The vehicle is programmed to shut down if after a certain length of time if no key has been inserted into the ignition, so after a few minutes the engine shuts down as it supposed to. It just didn't seem to recognise the fact there was a key in WIN. Has anybody had any experience like this. I have had suggestion on replacing the WIN. Guess what they are on backorder (what does that tell you). They're on backorder so there must be a lot of problems around but everybody so far are treating me like I'm the only one in the world that has encountered this problem. Can anybody help, or come up with a suggestion (even if it;s just replacing the WIN).Gord. boltonites@sympatico.ca
Old Jul 7, 2014 | 11:10 AM
Welcome. Please read the section descriptions so you post in the correct area. Moving to the Caravan section.
Old Jul 7, 2014 | 06:30 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
I do one every week or so. They shouldn't be on backorder. There are WIN kits available now that come with 2 new FOBs and a WIN module for I think around 350 bucks.
Old Jul 8, 2014 | 09:29 AM
gordyk's Avatar
gordyk
Thanks TNtech, Now in the hands of the dealership. Hope thay have a tech like you on site. They did mention the replacement WIN with the two key fobs. Said they would check to see what they could find and then replace if necessary. keeping my fingers crossed (that kit is $464 + $60 tax in Canada). Did you ever wonder why they should suddenly fail, like what cause that. In my case sometimes in would work for a few days, but this last failure seems like a total. Thanks again, gordykCANADA
Old Jun 2, 2015 | 09:21 PM
Suedatt's Avatar
Suedatt
Default 2008 Grand Caravan
No ignition, windows don't work. WIN module suspect, there is a recall on this item. Have an appointment at the dealer. Will update.
Old Jun 3, 2015 | 10:56 AM
TNtech's Avatar
TNtech
Um ok.
They should have a crapload of them in stock.
Old Jun 5, 2015 | 08:32 AM
WiRik's Avatar
WiRik
Default Recall Notice received
I just received a recall notice from Dodge ( FCA-Fiat Chrysler Automobiles to be exact) to replace the WIN module and FOBIK's on a 2010 Grand Caravan.
Had a similar recall done a few years ago, does anyone know if this recall will have improved components?
We have been experiencing intermittent issues with the 1st recall completed.
Here's hoping this second one will solve the problem.
Recall# R03/NHTSA 14V-373 was stated on the recall notice.
Old Jun 5, 2015 | 10:31 AM
TNtech's Avatar
TNtech
The L-25 recall was just blatantly cheap and stupid. This is a good fix as far as I can see.
Old Jun 6, 2015 | 09:42 AM
WiRik's Avatar
WiRik
Thanks TNtech, Let's hope this latest fix is good, and getting a couple new fobs is good!
Old Jun 9, 2015 | 10:01 PM
Suedatt's Avatar
Suedatt
Default Update
They replaced the WIN Module and the vehicle starts ok, got two new keys too. Will see how it works.
Plan to replace both lower arms and sway bar bushing and links.
