[2nd Gen : 91-95]: Need fast help with strut installation
Old Jul 12, 2014 | 03:01 PM
quattj's Avatar
quattj
Exclamation Need fast help with strut installation
Replacing strut assemblies (all in one) on my 95 Grand Caravan.
I purchased Moog Strut Assembly ST8505. The old struts had two big nuts and bolts and a figure 8 shaped metal plate on one side (the nut side) to attach the strut to the control arm (or whatever is at the bottom)
The new part does not include this figure 8 piece and one of the bolts has an oblong backing to it, while the second has a round backing.
Do I need to use the figure 8 from the old setup? Is there a particular reason why one bolt is oblong?
I have it mostly reassembled already and want to make sure I didn't screw anything up before putting the tire back on (and refilling my transmission fluid... surprise to me!)
Old Jul 12, 2014 | 03:18 PM
quattj's Avatar
quattj
Attached Thumbnails Need fast help with strut installation-img_1704_zps7504c961.jpg
Old Jul 12, 2014 | 04:14 PM
quattj's Avatar
quattj
Well, after furthur inspection, the oblong bolt is called a cam bolt and goes on the bottom. I swapped the two around, and did put the washer plate on. *fingers crossed* Oh, and refilled my transmission fluid...
After I do the other side I have to get an alignment for sure.
Old Jul 13, 2014 | 02:54 PM
master tech's Avatar
master tech
Site Moderator & Tech
The camber bolts go in the bottom holes not the top ones. Those are to set the camber when you have the vehicle re-align.
Old Jul 14, 2014 | 12:49 PM
smokesxt's Avatar
smokesxt
Yes the figure 8 piece should go on also.
Old Jul 14, 2014 | 03:18 PM
Tizzy1's Avatar
Tizzy1
Figure 8 goes on the nut side, FYI
