[5th Gen : 08+]: 2010 SXT 4 L Air Conditioning Problem
Old Sep 7, 2014 | 02:39 PM
2010SXT4.0L's Avatar
2010SXT4.0L
Default 2010 SXT 4 L Air Conditioning Problem
Hi all the compressor kicks in but the fans I am sure should be running but aren't . I am sure they kick in when temp rises . What do you think the issue is? Drivers side is cooler than passenger but not sure what that means. Overall it should be a lot colder.
Old Sep 7, 2014 | 11:00 PM
DodgeCaravan2010SXT's Avatar
DodgeCaravan2010SXT
like to actually see what the gas pressures are like, just assuming at the moment but I think should it be low on refrigerant possible you could get partial cooling.
Old Sep 8, 2014 | 09:41 AM
2010SXT4.0L
Does anyone know where the low side port is on these vans?
Old Sep 8, 2014 | 06:12 PM
DodgeCaravan2010SXT
smaller cap think if you look at the connection I think behind the air filter box think near the receiver/drier silver can looking.
Old Sep 9, 2014 | 11:03 AM
Tizzy1's Avatar
Tizzy1
The low side port is center van back by the fire wall on the suction line. Cold on one side and warmer on the other means low on Freon charge. I'd check the rear evaporator, known leak area.
Old Sep 9, 2014 | 05:30 PM
DodgeCaravan2010SXT
did they come with a proper fix for the rear evaporator?
Old Sep 10, 2014 | 11:03 AM
Tizzy1's Avatar
Tizzy1
nope
