[General]: torque specification for Dodge Caravan 2009 SE
Old 10-06-2014, 12:13 AM
nentendo's Avatar
nentendo
nentendo is offline
Default torque specification for Dodge Caravan 2009 SE
can anybody guide me for front and back wheel torque specification for Dodge Caravan 2009 SE 3.3
thanks
Old 10-06-2014, 09:00 PM
georgef's Avatar
georgef
georgef is offline
From the 2009 Caravan owner's manual:
Wheel Nuts
All wheel nuts should be tightened occasionally, to eliminate the possibility of wheel studs being sheared or the bolt holes in the wheels becoming elongated. This is especially important during the first few hundred miles of operation, and after each time a tire is changed, to allow the wheel nuts to become properly set. All nuts should first be firmly seated against the wheel. The nuts should then be tightened to recommended torque. Tighten the nuts to final torque in increments. Progress around the bolt circle, tightening the nut opposite to the nut just previously tightened until final torque is achieved. Recommended torque is 95 ft lbs (130 N·m).
George
Quick Reply: [General]: torque specification for Dodge Caravan 2009 SE
