[4th Gen : 01-07]: need help 03 caravan batery temp. sensor
03 caravan started acting up after rainy week. took it to autozone
told me it was 4-6 sensors replaced all and nothing. took it to the shop
they told me the connectors for the pcm were damaged.. replaced those
then they tell me its the pcm its gone bad.. replaced the pcm $600...
and problem persists they say its down to the battery temp sensor and the
coolant temp sensor.. new pcm and new coolant temp sensor and still same issue they took the van to an electrician for 2 weeks and found nothing...
its been a month w/o a vehicle... so far no assertive diagnostic.. if you all can help please.....
the temp gauge rises when start up then just drops seconds after
rough idle , hesitates to take off , got the alternator light on alternator checked out good twice... brand new battery, new pcm,
