[3rd Gen : 96-00]: 1999 Caravan Overheats
Old Oct 10, 2014 | 01:37 AM
yankeeboy's Avatar
yankeeboy
Default 1999 Caravan Overheats
Ok, so i changed the water pump, new upper and lower hoses, new radiator, new fluid, but for someone the car is overheating AND only when i turn the A/C on. I have no idea why this is happening. I have been driving the entire California summer without A/C, just because within 5 minutes of me turning on the A/C the car will over heat.
I've checked the fans, and both are woking properly. The moment the A/Cis turned on, the fan kicks in and stays on, even while in idle.
Anyone have any idea why this is happening?
Wondering if this is a sign the A/C is about to fail?
Old Oct 11, 2014 | 11:25 PM
yankeeboy's Avatar
yankeeboy
BUMP
Nobody has an idea on this issue?
Old Oct 14, 2014 | 10:28 PM
issakar's Avatar
issakar
Any advance on this issue? I'm interested in the resolution
Old Oct 15, 2014 | 04:09 PM
Cougar41's Avatar
Cougar41
Only thing you haven't touched on is a leaking head gasket blowing exhaust into the coolant. Why just when A/C is on? I'm scratchin my head a bit but maybe the added load forces the leak. There are combustion test kits available at reasonable prices. May be able to sign one out from AutoZone or the like: http://www.amazon.com/s/ref=nb_sb_ss...n%2Caps%2C1409 Or.... look for bubbles with the rad cap off.
Old Oct 15, 2014 | 04:13 PM
smokesxt's Avatar
smokesxt
When the AC turns on there is an added load on the engine, so bad head gaskets, or a bad water pump could cause the overheating under load (aka AC on).
Old Oct 15, 2014 | 04:17 PM
Cougar41's Avatar
Cougar41
Hey, thanks for the confirmation. My head appreciates it.
Old Oct 15, 2014 | 06:46 PM
issakar's Avatar
issakar
I also considered the added load of AC and was initially thinking fan related, but then OP said fans were good and I was like "whelp, I'm out on this one"
Old Oct 17, 2014 | 01:18 AM
yankeeboy's Avatar
yankeeboy
Never thought it could be the head gasket. I have to change the oil pan gasket, so might as well include the head gasket. I'll keep you guys posted, and hopefully that's all it is.
Old Oct 17, 2014 | 09:20 AM
issakar's Avatar
issakar
Let us know what you find out, I'm very curious about this problem
