[4th Gen : 01-07]: brake tube (line) replacement
Old Oct 12, 2014 | 06:17 PM
larry1030's Avatar
larry1030
Default brake tube (line) replacement
Has anyone replaced the driver side front brake line on 4th Gen (2002) GC with ABS? It is very hard to get to: I have followed the service manual procedure, removing the battery, battery tray, and moved the speed control survey out of the way.
The procedure now goes on to suggest removing all the brake lines from the ICU and remove the ICU itself by unbolting it from inside the car.
My question is, do I really need to do all that to get that left front brake line out and put in a new one? It is really snaked around behind the ICU, but has anyone been able to work it out without removing the ICU?
This particular line wraps around to the left (as seen from the front) and then back behind the ICU and to the right, then down near the wheel well and finally to the right to mate with the brake hose at the mounting bracket.
Old Oct 19, 2014 | 10:22 AM
IndyMike's Avatar
IndyMike
Your layout is different than the one on my '97 Caravan. I did find the following HCU diagram online
HCU: http://www.factorychryslerparts.com/...ey_model=15482
From the image, it looks like the same HCU used on my '97. Just mounted in a different location.
I can't tell you what you need to take off to get to the Drivers front line because I don't know the routing on your 2003.
The tube "assignment" for the HCU appears to be the same as for my '97. The layout for my '97 is:
