[5th Gen : 08+]: DRL Activation
Old Nov 15, 2014 | 10:26 AM
Hytec's Avatar
Hytec
Question DRL Activation
I have just purchased a 2013 Caravan SXT and discovered that it does not have Daytime Running Lights (DRL). I was told that the DRL function could be activated just by changing a code in one of the car's computer. Is this true? What is the code, and how can it be done? Thanks
Old Nov 15, 2014 | 12:45 PM
DodgeCaravan2010SXT's Avatar
DodgeCaravan2010SXT
I not sure if you have the module. but this has to be programmed by dealer if you do have that option. this is Canadian rule. some usa I believe have it as well. you need to check with the dealer.
Old Nov 15, 2014 | 03:21 PM
Hytec's Avatar
Hytec
Thanks for your reply. Where would I look for the DRL module? I don't want to ask the dealer if I don't have it.
Old Nov 15, 2014 | 03:32 PM
DodgeCaravan2010SXT
to be honest location of it I don't know.
Old Nov 21, 2014 | 05:05 PM
Montreal300's Avatar
Montreal300
Default DRL Activation
The dealer has access to the ECM software to enable DRL's. Unless you have a StarScan, you can't do it. It takes less than 10 minutes to do so just find a compliant dealer or someone that works at a dealership.
