[4th Gen : 01-07]: 2006 GC power rear vent window problem
Old Dec 11, 2014 | 12:17 PM
kenttt's Avatar
kenttt
Smile 2006 GC power rear vent window problem
It's a 2003 not a 2006, don't know how the title changed from '03 to '06
Am having trouble w/the RH power rear vent window, opens OK, but doesn't want to close. If you try the switch 20-30-40 or more times it will eventually work. Would this be a switch problem? Or is there a relay somewhere that might be a problem with?
Ifn it's the switch, how is it removed/replaced?
Anyone have a wiring diagram for this?
TIA, Ken
Old Dec 11, 2014 | 06:35 PM
Cougar41's Avatar
Cougar41
Just based on the odds the switch is fine, the window motor is on it's way out. This is a common fault with a common fix. Not to say it's not worth testing the switch. No there's no relevant relay. Send me a private message and include an email address to send the diagram to.
Old Dec 12, 2014 | 01:29 PM
kenttt's Avatar
kenttt
Ifn it is the motor going out as you suggested, how does one go about accessing it?
Looks like one big piece of plastic back there.
TIA, Ken
Old Dec 12, 2014 | 03:46 PM
Cougar41's Avatar
Cougar41
Something like this:
Old Dec 13, 2014 | 11:33 AM
kenttt's Avatar
kenttt
Thanks, now I just have to source a motor.
BTW, FWIW, I just hate all that plastic stuff w/clips that tend to break, rather have screws.
Old Dec 13, 2014 | 03:45 PM
Cougar41's Avatar
Cougar41
Amazon has them for $60. May find them cheaper elsewhere. I wouldn't recommend one off a junker. These motors are cheap and fail often. Once you get access you can test the switch from the motor connector. Should see 12vdc at pins 2 or 3 depending on which way you push the switch. X2 on those clips. They can be a PITA. If you run into a stubborn one slip putty knives on either side of it and pry. They do make a tool just for these clips.
Did you get the diagram? Was having problems.
Old Dec 14, 2014 | 11:04 AM
kenttt's Avatar
kenttt
Didn't get the diagram. That's my fault, I gave you my email address as dotcom and it should be dotca. Sorry about that.
Old Dec 15, 2014 | 10:28 AM
kenttt's Avatar
kenttt
Can the motor be repaired?
I did one on an Aerostar a few years ago and all the motor needed was new brushes. Couldn't source the proper brushes so I made some by cutting down GM alternator brushes.
Old Dec 15, 2014 | 04:00 PM
Cougar41's Avatar
Cougar41
Ok. Tried it again and it looks like it went through from this end.
Fix the motor? I think they are sealed but you'll have to look. I know you can change brushes on the door window motors. Alternator brushes? That's American ingenuity!
Old Dec 16, 2014 | 10:02 AM
kenttt's Avatar
kenttt
Actually Canadian, I'm in Red Deer, Alberta
