[4th Gen : 01-07]: 2003 Dodge grand caravan Transmission Help!!
Old Dec 24, 2014 | 12:49 AM
master tech's Avatar
master tech
Site Moderator & Tech
Disconnect all the wire connectors and see if you have any water in the pin. Water is not good for the wires. The water will act like a conductor and apply power to a circuit that isn't suppose to have power. Also do you think the transmission may have gotten water in the transmission?
Old Dec 24, 2014 | 09:53 AM
jws123's Avatar
jws123
i already cleaned all of the wires no change didnt get water in the trans i im going to have the module flashed and if that doesn't work replaced.
Old Dec 24, 2014 | 06:55 PM
speersy10's Avatar
speersy10
check your obd codes, there may be pending codes which may suggest a place to start,
some codes will not cause the check engine light to turn on right away.
