[4th Gen : 01-07]: Sliding door not opening
Old Dec 21, 2014 | 04:56 PM
rick31797's Avatar
rick31797
Default Sliding door not opening
I have a 2002 Caravan..the one sliding door will not open the other one does.
When i pull up on the lock manually to unlock, it will not pull up..This van does not have power sliding doors.
I am sure this is something common , can somebody tell me how they fixed there door.
Old Dec 22, 2014 | 11:03 AM
rick31797's Avatar
rick31797
I dont think the actuator is working , so will have to get the door panel off and check... is there any way to bypass the actuator , so i can use the door tell i get the part...
Old Dec 22, 2014 | 01:45 PM
rick31797's Avatar
rick31797
So i got the Actuator out , but still cannot open door... The Actuator does not move when i try moving it by hand... is it suppose to or an indication its frozen...
I Can not figure out why the door wont open.. wondering if it might have something to do with the gas lid..
but anyway when i plug in the actuator and hit the remote lock, it doesn't work, i wish i could use this door manually, tell i get the part.
Old May 9, 2017 | 04:32 PM
David Sawyer's Avatar
David Sawyer
I can not even get the dammed Interior door panel Off !! - The lock button is stuck in the down (Locked) position - so the sliding door will not open !! - - because I can not open the door - the interior panel can not be removed - and I can not there for access or fix any of the internal lock mechanisms Catch 22 - Frickin Stupid !!
