[4th Gen : 01-07]: 06 Grand Caravan SXT sliding door is "skipping"
I've had a rough time with the doors on this van. I've replaced both lock actuators myself and fixed a couple of broken wires in the looms inside the plastic chains.
My problem now is that when the passenger side sliding door is all the way open, attempting to close it via the fob or internal buttons causes it to fail to engage properly, skipping, stuttering, and generally sounding like a machine gun until someone grabs the handle manually to stop it.
I suspect that either something has a worn or broken gear, or that some cable tension needs to be adjusted.
I can post pics or a video if it helps. I am pretty comfortable with the internals of these doors and I follow instructions well, so if you have things for me to try or links to read, just send them my way. Thanks!
Also, if I am unable to fix this myself, would a body shop be preferable to the dealer? I should be able to handle it unless something major or heavy is wrong. If the door needs to come off, for example, I will probably want to call in the pros - either body shop or dealer.
