[4th Gen : 01-07]: Help coolant leak !!
Old Jan 22, 2015 | 07:51 PM
plucious's Avatar
plucious
Exclamation Help coolant leak !!
Trying to figure out why and where coolant leak coming from that soaking driver side floor and fogging up the windows. We flushed out radiator which seem to stop stinky steam but we are losing coolant still on to the floor ,what and where could this be coming from ?
2006 dodge grand caravan
Old Jan 22, 2015 | 08:00 PM
hoosierrun's Avatar
hoosierrun
I believe your heater core is connected to the inlet and outlet tubes (that pass through the firewall) via some clamps and O-rings. It sounds like an O-ring is leaking through. It could also be the heater core leaking. On these newer vehicles, the heater core can be replaced without removing the entire dashboard, however, the job is still not real easy on your vehicle because of a few things that have to be removed from under the dash, and the tight working conditions in that area.
Old Jan 22, 2015 | 08:03 PM
grog11's Avatar
grog11
You have a leak in your hvac heat exchanger coil that is internal to the blower assembly under your dash. You will need to get it replaced.
