[4th Gen : 01-07]: 06 Grand Caravan Crank no spark
Old Jan 23, 2015 | 11:33 AM
doowon's Avatar
doowon
Default 06 Grand Caravan Crank no spark
Hello,
I have a 06 Grand Caravan 3.8L and it crank but no start(no spark). First, car suddenly stop on the road, just before than gas paddle was hard need to put little pressure to break the peddle tension after 1-2 min later it stop the engine. I had scanner and checked showed P01222 and P0129 two codes. Called AAA then take to nearest garage, they said showing 9 codes include crank shaft, cam shaft. Replaced TPS and crank shaft sensor but no start. Checked spark from the cable there was no spark. It has 150,000 miles on it and recently replaced Spark plug, cable, EGR valve, down stream O2 sensor, and at the garage replaced TPS and crank sensor. I will tow to house and take one by one to check.
Thank you in advance.
