[3rd Gen : 96-00]: 3.0L Caravan rough running, bad MPG
Old 01-22-2015, 10:54 PM
issakar's Avatar
issakar
issakar is offline
Default 3.0L Caravan rough running, bad MPG
Greetings forum folk,
I have a 99 caravan w/ the 3L engine. 151k miles. I've had low power with it lately, taking a lot to get up to speed. I also have been averaging about 17MPG with mostly hwy driving which seems pretty poor. Additionally when idling I can feel a bit of a stumble/rough idle.
I'd like to solve this issue, and I'm looking for a direction. I picked up a block tester and plan to test for combustion gasses in the coolant just to rule out (or confirm) head gasket issues. I'm sorta leaning towards a lean condition/vac leak, and I'm hoping to have a scan tool soon that can get me some live data.
I am probably due for a tune up; I've put around 25k on it since I"ve owned it, and I'm not sure when the previous owner last did any type of plugs/wires/cap/rotor. I also don't like to throw parts, and much prefer to have evidence to back up my decision.
Old 01-23-2015, 10:16 AM
hoosierrun's Avatar
hoosierrun
hoosierrun is offline
When was the timing belt and timing belt tensioner last changed? Low power and poor gas mileage could be related to a timing belt that has slipped a tooth on a sprocket... or was not properly lined up on a recent installation.
Another possibility could be related to a clogged or restricted exhaust system (converter perhaps).
Head gasket problems are less likely on a 3.0.
Old 01-26-2015, 07:36 AM
smokesxt's Avatar
smokesxt
smokesxt is offline
Disagree on the timing belt/tensioner. I've never needed to replace either, other then when a water pump went out.
Converter is a definite possibility.
Just needing the plugs/wires/cap/rotor done can also be contributing to all the issues, seeings it's at 150+k. I would start there seeings it most likely needs to be done anyway.
Quick Reply: [3rd Gen : 96-00]: 3.0L Caravan rough running, bad MPG
