[4th Gen : 01-07]: no spark till 8 revolutions
Old Feb 17, 2015 | 08:13 AM
ddgrampage's Avatar
ddgrampage
Check codes 6 total now. P0344 cam circuit intermittent shows twice, p0129 berometric pressure too low shows twice, p0700 transmission control system, p0562 voltage low. Cleared them. Charging battery at the moment.
Old Feb 17, 2015 | 08:24 AM
ddgrampage's Avatar
ddgrampage
Idle is still high around 1300 rpm today. The studder moved frome 2500 rpm to 4000. Engine seems to being running smoothly. Check engine light still off from reset
Old Feb 17, 2015 | 01:34 PM
ddgrampage's Avatar
ddgrampage
2 codes came back. P0344 which comes up twice. The spudder is back at 2500 rpm
Old Feb 18, 2015 | 02:00 PM
cv2003's Avatar
cv2003
You repaired the sensor wire, and that worked for a while. If you haven't already done so, you should unwrap that repair and check to see that it's still intact.
