[4th Gen : 01-07]: no spark till 8 revolutions
Old Jan 23, 2015 | 09:11 AM
ddgrampage's Avatar
ddgrampage
Default no spark till 8 revolutions
Have a 04 grand caravan the will start after 8 rotations everytime. Doesn't get spark until the 8th rotation. When it starts it will idle fine. Drivin down the road it falls on its face around 2700 rpms. Have replaced crank sensor, cam sensor, coil, ecu reflashed. Not sure what could be the problem
Old Jan 23, 2015 | 10:09 AM
hoosierrun's Avatar
hoosierrun
I assuming there are no error codes and if there are none, this problem can often be caused by a bad fuel pump module. The fuel pressure should be checked under different conditions and especially check to insure that pressure remains at spec after the engine has been shut off and has sat for several minutes.
Old Jan 23, 2015 | 02:32 PM
ddgrampage's Avatar
ddgrampage
There are no engine codes. Fuel pressure is where it should be.
Old Jan 23, 2015 | 09:06 PM
Cougar41's Avatar
Cougar41
Even after the van has sat over night?
Old Jan 30, 2015 | 09:59 AM
ddgrampage's Avatar
ddgrampage
New fuel pump. No change. Have been switching other sensors with a donor van with no luck.
Old Jan 30, 2015 | 11:14 AM
ddgrampage's Avatar
ddgrampage
Have some good news. Was playing with the cam sensor and noticed a wire that was rubbed in half.
Old Jan 30, 2015 | 12:30 PM
hoosierrun's Avatar
hoosierrun
Thanks for the report. Your description matches a cam sensor malfunction. On the gen 3 and later vehicles, a cam sensor malfunction will still allow the vehicle to start (in most cases), but it takes a bit of cranking.
I'm surprised there was no code.
Old Jan 31, 2015 | 04:02 PM
Cougar41's Avatar
Cougar41
More evidence the OBD system is not all it should be.
Do you recall the wire ID colors?
Old Feb 16, 2015 | 11:15 AM
ddgrampage's Avatar
ddgrampage
The broken wire fixed it. But the next day it was back to the same problem. Started putting old sensors back in. Still nothing. new plugs and wires, slight improvement at idle. Noticed alot of moisture out of exhaust. Idles high around 1500 rpm.
Not sure what is ment by wire color id.
Old Feb 16, 2015 | 12:11 PM
hoosierrun's Avatar
hoosierrun
Is there still a code for the cam position sensor?
(be sure to reset the old code first... then after several tries, see if the code comes back)
