Usually on minivan.net
Old Jan 27, 2015 | 01:32 PM
Mickeys240's Avatar
Mickeys240
Default Usually on minivan.net
Was looking at this thread and wanted to fix my lights on my Town and Country Minivan 1999:
https://dodgeforum.com/forum/1st-gen...t-working.html
I am not able to see the posted links:
Old 01-09-2007, 09:07 AM
dodgerules86's Avatar
dodgerules86 dodgerules86 is offline
Vehicle: 1996 Dakota 4x4, 3.9L, extended cab, automatic.
Default RE: Low beam headlights not working
You are correct in what each wire is for.
Light green is power from the headlamp switch when headlamps are selected.
Light green/black is constant power from the headlamp switch for the high beams.
Violet/white is power to the low beams
Red/orange is power to the high beams
There is no fuse or relay between the dimmer switch and the headlights.
There is, however, the bulk-head disconnect. Cavity 5 of the bulk-head disconnect is for the low beams, and cavity 6 is for the high-beams.
[IMG]local://upfiles/948/C1BAD7777F824754B2650C1FEFE9C3D8.jpg[/IMG]
[IMG]local://upfiles/948/A4809BF21FDA43F4BB8E46C59BA53CA4.jpg[/IMG]
[IMG]local://upfiles/948/09DC924D7E924AE38B298DAC88A005B2.jpg[/IMG]
__________________
If parts ain't flyin', you ain't tryin'.
1996 Dodge Dakota, 4x4, extended cab, 3.9L, automatic. - my baby
2012 VW Jetta Premium with Nav, 2.0L TDI diesel, 6-speed manual - the daily
Traded: 2009 Toyota Corolla S, 1.8L, 5-speed manual
So wanted to see if anyone had any ideas.
Oh and Hello!
Old Jan 27, 2015 | 04:10 PM
hoosierrun's Avatar
hoosierrun
Your 1999 T&C will have a relay for both low beams and high beams. That relay should interchange with the accessory outlet relay, allowing you to do a quick check to see if the relay is the problem. There is probably an associated fuse next to the relay so be sure to check it too.
Old Jan 27, 2015 | 04:35 PM
Cougar41's Avatar
Cougar41
First, chuck the info in that Dodge Dakota thread into the circular file. Too many differences between a Dodge Dakota and a minivan to be relevant. Now, what's wrong with your headlights?
