[4th Gen : 01-07]: Can someone please tell me how to bleed
Old Feb 24, 2015 | 03:39 PM
01Caravan_sil's Avatar
01Caravan_sil
Default Can someone please tell me how to bleed
Can someone please tell me how I am supposed to bleed the brakes on a 2001 2.4 Dodge Caravan? I cant find how to do this ANYWHERE on the internet.
Old Feb 25, 2015 | 10:47 PM
master tech's Avatar
master tech
Site Moderator & Tech
Do you have ABS brake system? First you want to do a manual bleed, master cylinder full and the bleed the right rear, left rear, right front and then the left front. And if you have ABS, then you need a scanner and bleed the ABS module.
Old Feb 27, 2015 | 09:48 PM
tjnc's Avatar
tjnc
I basically do it the old way, and mine all have 4-disk ABS. I just keep the cap on as much as possible to avoid moisture. I don't even have a drain kit, I have a soda bottle with the hose under fluid to avoid back-flow of air.
The only thing scary about doing your own breaks is the risk of breaking a lug-bolt or having to return pads that don't match up to new calipers..
