[5th Gen : 08+]: 2009 Grand Caravan front blower
Old Apr 19, 2015 | 08:19 PM
mspope's Avatar
mspope
Default 2009 Grand Caravan front blower
My front blower has quit. Rear blower is fine. I can't find the front blower relay and fuse in the Integrated Power Module (Some of the writing on the cover is rubbed off). Can anyone tell me? Does anyone have an IPM diagram?
Old Apr 20, 2015 | 10:34 AM
Tizzy1's Avatar
Tizzy1
There is no fuse and no relay. The feed to the blower motor from the TIPM is internal. If you are not getting power out to the blower motor, the TIPM would have to be replaced.
Old Apr 20, 2015 | 02:45 PM
Cougar41's Avatar
Cougar41
Ditto to Tizzy1. I can send a diagram for a 2008 model. Should be the same as your 2009. I'll need an email address to send it to via a private message. How? Click Cougar41 at left.
BTW - You have a TIPM not an IPM. Big difference in function.
Old Apr 20, 2015 | 06:12 PM
mspope's Avatar
mspope
Thanks for your responses, I'll check for power at the blower...
Old Apr 20, 2015 | 10:58 PM
mspope's Avatar
mspope
With the help of this video
I was able to locate the blower power connecter and I am happy to report that I have 12 volts. The video above also demonstrated that removal of the blower was allot easer than I was originally lead to believe (didn't have to loosen the whole dash). Off to NAPA for a replacement. BTW the thing had been squeaky at low speeds for a while.
