[General]: Wiring rear speakers
Old Jun 27, 2015 | 06:57 PM
Flotownson's Avatar
Flotownson
Default Wiring rear speakers
How do I wire the six wires correctly to a new speaker? I had to cut the plug and I can get sound but doesn't seem as loud as it should be
Old Jun 28, 2015 | 08:17 AM
Speakers need only 2 wires.
Old Jun 28, 2015 | 10:05 AM
tjnc's Avatar
tjnc
There are inline amplifiers on most of these vans depending on options. There will be at least positive, negative, audio positive, audio negative, and the other is probably a signal wire from the radio to power on the amp at a certain ignition state.
Give year to get wiring diagram
Old Jun 28, 2015 | 12:38 PM
Flotownson's Avatar
Flotownson
Default Speaker wiring
2002 Dodge Caravan....I have found wiring schematics but only show two wires to each speaker!?!
Old Jun 28, 2015 | 12:59 PM
Flotownson's Avatar
Flotownson
Old Jun 28, 2015 | 04:22 PM
tjnc's Avatar
tjnc
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Green/Black
Right Front Speaker Positive Wire (+): Gray
Right Front Speaker Negative Wire (-): Gray/Black
Left Rear Speaker Positive Wire (+): Green/Black
Left Rear Speaker Negative Wire (-): Green/Orange
Right Rear Speaker Positive Wire (+): Gray/Black
Right Rear Speaker Negative Wire (-): Gray/Pink
Use a multi-meter, steady amp will be the +/- for the amp, and fluctuating will be audio, no or low current and ground will be signal.
The stock stereo isn't going to push aftermarket speakers unless they are extremely low watt 4ohm. I'd imagine 35 watt speakers would even under-perform. I'd try 5-15 watt. Freuquecy matching the speakers isn't as important because any speaker that can RMS the power is going to have some responsive range.
Old Apr 20, 2020 | 06:06 PM
Chris Guidry's Avatar
Chris Guidry
How do I find positive and negative on the rear speakers of my 2002 Dodge caravan
