[4th Gen : 01-07]: abs codes...help please
Old Jul 16, 2015 | 11:22 PM
josh.simon's Avatar
josh.simon
Default abs codes...help please
So I have 2002 grand caravan es and am currently overhauling the van...I am having abs issues and am pulling 4 codes...
02 left front wheel speed /signal failure
11 unknown
13 unknown
16 missing rf sensor
my scanner wont define 11, and 13 and I cant erase them....I even tried to unplug battery for about 24 hours and wont clear....is this meaning a faulty module??
i bought the van about 2 yrs ago and always had abs and t/c light on, before i only used to get a code 02 and p/o had changed wheel speed sensor twice without any results.....p/o is my uncle so I got the info from him, he said it turned light on right after getting tranny rebuilt...or around same time
i haven't noticed any driveability issues however abs and traction control never turn on, and occasionaly the brake pedal will suddenly drop slightly while aggressive breaking as if abs is doing something pedal prob only sinks about 1/4 inch and breaking is still excellent and firm, just pedal drops.....I am about to get into this diagnosing right after i change, steering rack, sending unit, and filter, o2 sensor, rear heater core hoses, sway bar bushings, and break service.....gonna do that tomorrow and prob sun tear into the abs issue....I love the van but all the little things have been driving me nuts....and i want traction control working for this winter so any help would be awesome....thanks
Old Jul 16, 2015 | 11:25 PM
master tech's Avatar
master tech
Site Moderator & Tech
Have you try replacing the sensor? Or switch the left to the right side and see if the code go's with sensor?
Old Jul 16, 2015 | 11:36 PM
josh.simon's Avatar
josh.simon
yep when i bought it it only one code 02 lf wheel speed sensor low voltage, and that sensor had been replaced twice without success, i then tried to inspect tone ring and cleaned it up nice with wire wheel and still no luck, now a few more codes and i don't understand the code 16 missing rf sensor....i hope that is referring to a tpms sensor and not wheel speed sensor.....i haven't tried swapping them yet, but figured the two new lefts was good enough to eliminate that sensor....should i try switching sensors? or maybe continuity test on wires back to module??
Old Jul 16, 2015 | 11:44 PM
master tech
Let me find some information for you and I'll be back.
Old Jul 16, 2015 | 11:46 PM
josh.simon's Avatar
josh.simon
thank you very much.....and very fast....thanks again...i will be here when u return....hehehe
cheers
Old Jul 16, 2015 | 11:49 PM
master tech
Test Note: All symptoms listed above are diagnosed using the same tests.
The title for the tests will be LEFT FRONT SENSOR CIRCUIT
FAILURE.
When Monitored and Set Condition:
LEFT FRONT SENSOR CIRCUIT FAILURE
When Monitored: Ignition on. The CAB monitors the wheel speed circuit every 7
milliseconds (ms).
Set Condition: If the CAB detects an open or shorted wheel speed sensor circuit, the
Diagnostic Trouble Code (DTC) will set.
LEFT REAR SENSOR CIRCUIT FAILURE
milliseconds (ms).
RIGHT FRONT SENSOR CIRCUIT FAILURE
milliseconds (ms).
RIGHT REAR SENSOR CIRCUIT FAILURE
milliseconds (ms).
POSSIBLE CAUSES
SENSOR OR CONNECTOR DAMAGE
WHEEL SPEED SENSOR FAULT
SENSOR CIRCUITS SHORTED OR OPEN
36
BRAKES (CAB)
Turn the ignition on.
With the DRBIIIt, record and erase DTC’s.
Turn the ignition off.
With the DRBIIIt, read DTC’s.
Does the DRBIIIt display a Wheel Speed Sensor Circuit Failure DTC?
All
Yes ! Go To 2
No ! Go To 5
2 Turn the ignition off.
Inspect the affected Wheel Speed Sensor and Connector.
Is the Sensor or Connector Damaged?
All
Yes ! Repair as necessary.
Perform ABS VERIFICATION TEST - VER 1.
No ! Go To 3
3 Turn the ignition off.
Disconnect the affected Wheel Speed Sensor connector.
Note: Check connector - Clean/repair as necessary.
Using a 12-volt test light connected to ground, check the Sensor 12 volt Supply
circuit.
Measure the resistance between ground and the Sensor Signal circuit.
Was the test light bright and the resistance between 100 and 300 ohms?
All
Yes ! Replace the Wheel Speed Sensor in accordance with the Service
Information.
No ! Go To 4
4 Turn the ignition off.
Disconnect the CAB connector.
Check the Wheel Speed Sensor 12 volt Supply and Signal circuits for a short to
battery, ground, to each other and for an open.
For the purposes of this test, a short to ground must be below 15k ohms.
Was any circuit short or open found?
All
Yes ! Repair the Wheel Speed Sensor circuit short or open.
No ! Replace the Controller Antilock Brake.
ACTION APPLICABILITY
5 Turn the ignition off.
Visually inspect the related wiring harness. Look for any chafed, pierced, pinched, or
partially broken wires.
Visually inspect the related wire harness connectors. Look for broken, bent, pushed
out, or corroded terminals.
Refer to any Hotline letters or Technical Service Bulletins that may apply.
Were any problems found?
All
No ! Test Complete.
Remember have the use of a DRB 3. That's the scanner we use.
Old Jul 17, 2015 | 12:00 AM
josh.simon's Avatar
josh.simon
great thanks for the info, i will check resistance of sensors and also verify ref voltage before checking circuits to module...i have my own scanner and not a good one but all i got to pull codes, also do u know what codes 11, and 13 mean? i cant find that info anywhere.....thanks again for specs and diagnostic flow
Old Jul 17, 2015 | 12:15 AM
master tech
dealerconnect doesn't show codes by numbers. So I don't know what they mean.
Old Jul 17, 2015 | 11:33 AM
josh.simon's Avatar
josh.simon
ok its an innova 3100 abs scanner....for those codes it telss me to visit their website but no info on their site anyway, i will just trouble shoot every sensor and double check wiring to module, and prob have to replace module...that flow chart makes diagnosis really easy quick and fast....thank you so much....one last thing....is there a way to check tone ring other then a visual inspection?? is there a certain a/c voltage i should be receiving when spinning by hand?? or just any increase in voltage is sufficient??
Old Jul 17, 2015 | 11:35 PM
master tech
Yes. Hook up the ohm meter or DVOM on a/c at the sensor connector and spin the tire. You should get a small amount voltage reading. That would be the same as RPM reading thru the ABS module.
