[4th Gen : 01-07]: 2006 Dodge Grand Caravan. Power window will not come down.
Dodge CaravanThe Dodge Caravan is the best selling mini van from Dodge. How many Dodge Caravan owners here at DodgeForum.com would agree? Discuss it now!
Sometimes my power windows won't come down unless I hold the window switch down and slam the door shut. Is there anything that I can put on the door seal where the window goes into so the window can come down?
You can use a silicone spray lube on the guides. More commonly the motor is headed south. You can try disassembling and cleaning the motor brush area, replacing the motor or replacing the regulator assembly - the whole shabang.
Have had this problem, used the silicone spray made no diff, took aprt twice, tested motor both times and worked fine,
finally fouond it to be a gamey window switch, replaced now works great.
