[4th Gen : 01-07]: Rear Tires Wont Turn -- Unseize Best Approach?
Old Jul 29, 2015 | 01:46 AM
quantass's Avatar
quantass
Question Rear Tires Wont Turn -- Unseize Best Approach?
I own a 2002 Dodge Caravan. It has been parked for a few months and now the rear wheels dont turn when i drive forward or reverse. Also the E-brake pedal doesnt depress down.
I have to assume this is all due to rust. What is the best approach to getting these rear wheels to turn again and the E-brake cable to behave properly again.
Thanks.
Old Jul 29, 2015 | 07:58 AM
Drums or disks? At any rate, remove the wheels and remove the drums/calipers and lube everything up real good. (not the pads/shoes themselves obviously)
Old Jul 29, 2015 | 01:10 PM
tjnc's Avatar
tjnc
A bent axle, e-brake, and dry or seized hub can only cause this. Frozen calipers and bad brakes can't overcome the FWD pull. Lube stuff
The back-end of these are pretty simple, just axle, leaf springs, brakes, and ABS sensors if enabled. No independent suspension and drive system etc..
Old Jul 30, 2015 | 01:12 PM
quantass's Avatar
quantass
It is drum brakes. I will jack it up and use a sledge hammer to remove the hub and then lube as suggested.
Old Jul 30, 2015 | 03:30 PM
Count on warped drums if you are serious....
