[2nd Gen : 91-95]: 94 Caravan Brake Drum Issue
Old Sep 25, 2015 | 07:57 AM
Gundham456's Avatar
Gundham456
Default 94 Caravan Brake Drum Issue
Any help would be appreciatted! I have a Base Caravan FWD I need to replace the drums. But I can t find the right ones. The rear axle has spindles. I have all new wheel bearings and seals, but cant find the drums anywhere. The drums are the ones that have the studs already in them. Hope someone can help. Thanks so much
Old Sep 25, 2015 | 12:17 PM
Take a picture. The studs should be on the spindle/hub, not the drum.
Old Sep 25, 2015 | 12:40 PM
smokesxt's Avatar
smokesxt
The hub is likely stuck in the drum. If you are replacing the drums anyway drop the drum, studs up on the floor. The hub should fall out after a couple drops.
Old Sep 26, 2015 | 12:59 PM
Gundham456's Avatar
Gundham456
Thanks for the reply.I think your absolutely right. Drums are so rusted they look like all one piece. Ill upload the pics here to confirm. Tried beating them out but wont budge.
Attached Thumbnails 94 Caravan Brake Drum Issue-img_0001.jpg   94 Caravan Brake Drum Issue-img_0002.jpg
Old Sep 28, 2015 | 07:03 AM
smokesxt's Avatar
smokesxt
That's what I recalled. Same as our van and my car. Either keep working at them, or get new ones.
I couldn't get mine to budge beating them when I did the rear disc conversion on my car. Holding them about chest level and dropping them on the concrete floor worked after about the 3rd drop, the hub fell right out.
Old Sep 28, 2015 | 10:38 AM
Gundham456's Avatar
Gundham456
I got them out, Instead of dropping them, I sprayed penetrating oil around all the bases oh the studs and around the hub center. Let em soak for a few hours. Placed a used set of lugnuts on the studs and using a 2x4 and a hammer I was able to knock them loose. fell right out. Thanks for all your help, saved me alot of pain as it never occured to me that the hubs were separate from the drums. Stupid Chiltons Manual never once mentions them.
Old Sep 29, 2015 | 07:06 AM
smokesxt's Avatar
smokesxt
You're welcome.
I've pretty much learned these vans, and AA body cars from experience, as many times the chilton/haynes either doesn't supply the info, or the info is wrong.
