'97 Voyager - tap tap tap
Old Sep 5, 2008 | 04:18 PM
  #21
Metallheadd's Avatar
Metallheadd
Definitely not a cam follower. I had a plug wire come off and realized my 3.0 is OHV.
Old Sep 12, 2008 | 06:18 PM
  #22
Metallheadd
Well I am 400+ miles into my Trans fluid solution and so far no change. I am gonna change my oil tomorrow, I guess its gonna rattle unless I get mechanical on its ***. Any suggestions?
Old Sep 12, 2008 | 07:59 PM
  #23
COMP's Avatar
COMP
sorry,,,but it should be clean when you pull the cover
Old Sep 12, 2008 | 08:06 PM
  #24
Metallheadd
Absolutly, I have no regrets it was worth a try.
Old Sep 13, 2008 | 05:54 AM
  #25
BenHertz's Avatar
BenHertz
What kind of oil are you going to use?
Old Sep 13, 2008 | 09:09 AM
  #26
Metallheadd
Well probably something cheap like Quakerstate just to get it changed. I run Castrol syntech in my wifes car and GTX in my truck.
Old Sep 13, 2008 | 10:00 AM
  #27
COMP's Avatar
COMP
you going to pull valve cover ?
Old Sep 13, 2008 | 12:43 PM
  #28
Metallheadd
I would like too. If its just a push rod that could be a cheap fix. Do these engines have non-adjustable valves, just torque the nut and done or do I need to clock the crank and tighten in sequence? I guess I should get a manual first. O'Reilly auto has the gaskets for $17. I just want to keep my invested money low. I bought this van for $500 as a work beater but now I really like it. Never thought I would say that about a minivan.
Old Sep 13, 2008 | 01:55 PM
  #29
COMP's Avatar
COMP
wow,,ya get the book,,you have a good margin to work with there
Old Sep 15, 2008 | 04:08 PM
  #30
Metallheadd
Well I changed my oil yesterday, definitly quieter than it was, but still tapping. Probably quieter due to new oil.
