[4th Gen : 01-07]: rear wiper and washer don't work
Old Jan 29, 2016 | 03:44 PM
georgi's Avatar
georgi
Default rear wiper and washer don't work
I have Dodge caravan 2001 2.4L. The rear wiper doesn't work. No sound. Then I found the rear washer not working too – no sound. Nothing is frozen.
Please advise.
Old Jan 29, 2016 | 09:41 PM
Check fuses.
Old Jan 30, 2016 | 09:40 AM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
There was a BCM software update for that.
TSB # 08-003-01
Old Jan 30, 2016 | 10:49 AM
Cougar41's Avatar
Cougar41
Looking at several forums some have had luck disconnecting the negative battery cable a few minutes. Pulling the IOD fuse may do the same. The Techical Service Bulletin (TSB) involves reprogramming or replacing the Body Control Module (BCM).
Old Oct 17, 2016 | 02:33 PM
georgi's Avatar
georgi
It works. Thank you.
Opened the hood, opened the fuse box and pull the IOD fuse 15A for a couple minutes and then reinsert. Now the rear washer pump and wiper work again. Attached diagram.
Old Oct 17, 2016 | 03:10 PM
TNtech's Avatar
TNtech
They'll quit again....eventually.
