[4th Gen : 01-07]: AC fan blows high only
Old Mar 22, 2016 | 02:49 PM
Jennifer Hardy's Avatar
Jennifer Hardy
Default AC fan blows high only
2002 Dodge Grand caravan Sport 3.3... Ac fan only blows on high, otherwise depends on how fast I am going to force air through. And, it is not always blowing cold, comes and goes. Seems like sometimes if I hit a pothole it jars something and then it works a while! The heater comes and goes too.. mostly NOT... Crazy!
Seems like I read somewhere that the high blower has a separate fuse from the lower speeds, and that may be the problem.. that fuse may be blown. But I only see one fuse for AC blower... so not sure that is the reason.. Also.. the AC makes a high pitched squealing noise when I first put it on, then it fades off after a few seconds.. also sometimes that sound is accompanied with a flapping noise, like the fan is struggling or something, then it goes away after it gets going.. I think it is possessed!
Old Mar 22, 2016 | 02:56 PM
Jennifer Hardy
Default Forgot to add..
Forgot to add.. when I turn on AC.. makes a high pitched squeal for a few seconds then fades off..
Old Mar 22, 2016 | 02:57 PM
Could be the blower resister going bad or a bad connection to the resister.
Old Mar 22, 2016 | 03:03 PM
Jennifer Hardy
Where are resistors located?
Old Mar 22, 2016 | 03:06 PM
Cougar41's Avatar
Cougar41
Probably among the most common problems on these minivans over the years. The most common fix? The blower resistor block. Here's a video all about it:
Old Mar 22, 2016 | 03:16 PM
Jennifer Hardy
Hah ha! I just looked it up on YouTube myself! Found a similar video! Thanks! Now... just got to figure out why it doesn't blow cold all the time... seems I read something about maybe something loose in the dash or ignition switch??
Old Mar 22, 2016 | 03:29 PM
Or it's low on refrigerant.
Old Mar 23, 2016 | 03:53 PM
Cougar41's Avatar
Cougar41
Can you hear the mode/blend door actuators moving as you change vent modes?
