[4th Gen : 01-07]: front heater/AC fan: tried all the suggestions, still stuck
Looking at a '03 manual, Fuse 20, 25 amp in IPM.
You will only get blower motor power with ignition switch turned to RUN.
Power is applied to one side of the motor on a DARK GREEN WIRE. The resistors are tied to ground on one side thru the speed switch and to the blower motor on the other side thru splice S224 on a BLACK/TAN WIRE.
In the wiring diagram, the relay has terminal numbers on them. The relays have these numbers on them as well. You should have battery power key on or off at terminals 30 and 86. If you do, jump 30 to 87 and see if you now have power at the fuse. If you don't have power at 30 and 86, it is internal to the PDC
Voltage present (measured) at a terminal is just potential. It means little due to the fact that you're supplying the ground, otherwise there is no flow. Downstream of the ground side of the blower is where the action is. Resistor determines the speeds. Fan switch determines what circuit of the resistor the power is routed through, whether it be ECU signaled to a resistor module or hardwired.
