[4th Gen : 01-07]: Routine Thermostat Replacment?
Old Jun 28, 2016 | 12:50 PM
offgas's Avatar
offgas
Default Routine Thermostat Replacment?
I have two Caravans, a 2000 and a 2006. Both have original thermostats that regulate the temperature quite nicely at 192° according to my scan tool. Should I replace them for no real reason, or leave them in? Would new thermostats have the same chance of failing as the original installed ones?
Many thanks to all.
Old Jun 28, 2016 | 02:03 PM
Cougar41's Avatar
Cougar41
Flip a coin and there's your answer. I change them at 100K miles unless I have problem. My last problematic t-stat was back in the 70s.
Old Jun 29, 2016 | 01:53 PM
PWR's Avatar
PWR
A thermostat can fail as a result of many opening/closing cycles. I had one fail where the housing broke because of the many open/close cycles and the thermostat stayed open position.
The thermostat was the original thermostat and was at least eight years old and 200K+ miles at the time.
Old Jul 8, 2016 | 04:08 PM
Ron Pauly's Avatar
Ron Pauly
My van wouldn't warm up and when i took the housing off the thermostat was in two pieces just like others had experienced.Its a easy fix.
