2001 caravan se idles rough when stopping or stoped
Old Nov 10, 2005 | 10:31 PM
garman06's Avatar
garman06
Default 2001 caravan se idles rough when stopping or stoped
What would be the first thing I shuld check ? I need to know what tune up is recomended at 60,000 mi ? Thanks to all who reply!
Old Dec 24, 2005 | 06:22 PM
jeffl's Avatar
jeffl
Default RE: 2001 caravan se idles rough when stopping or stoped
Not sure if it's the same thing that happened to mine, but I'll try to explain it.
Ours would almost die when slowing down or sitting idle. This was whether it was a cold engine or warm engine. It got so bad you would have to ride the brake and gas when you came to a stop.
After trying several things (new fuel filter, fuel cleaning stuff), we had the Auto Idle Sensor (AIS) replaced. The part cost $20 and the labor was around $40. It only took a few minutes for them to do it. From what the mechanic said, it's a very common failure on this model. Ever since, it has ran fine. Looking back it may have been something easy enough to replace myself, but it was the local mechanic that figured it out, so I never even seen the part get changed or I would offer some help on how to do it.
Jeff
