[4th Gen : 01-07]: ABS and Brake Light warning lights stay on
Old Oct 7, 2016 | 12:54 PM
ctrain33's Avatar
ctrain33
Default ABS and Brake Light warning lights stay on
Does anyone have any suggestions as to the cause of the ABS and Brake Lights warning lights staying on...2002 Grand Caravan...I've tested the sensors and the Brake fluid level...all are good...
Thanks for your help!!!
Old Oct 7, 2016 | 07:53 PM
Cougar41's Avatar
Cougar41
Connect a scanner capable of reading ABS fault codes. The code will point you in the right direction.
Old Oct 8, 2016 | 12:35 PM
ctrain33's Avatar
ctrain33
Thanks for your reply...unfortunately the car is off the road and I don't have access to a higher level scanner that give abs codes...
Do you know if I actuate the key 3x, will it give me ABS fault codes???
Old Oct 8, 2016 | 05:36 PM
Cougar41's Avatar
Cougar41
The key dance will only give you powertrain codes.
