[5th Gen : 08+]: 2012 Caravan Rack and Pinion change
Old Nov 21, 2016 | 04:27 PM
frogjaw's Avatar
frogjaw
Default 2012 Caravan Rack and Pinion change
I have a 2012 Caravan, my daughter hit something and bent the tie rod end. How hard is it to change the rack and pinion.
Old Nov 22, 2016 | 04:18 PM
TRU's Avatar
TRU
The tie rod screws into the rack and pinion, you'll see it if you unclip and pull the rubber boot back. So you shouldn't have to change the rack unless she damaged both the tie rod and rack. Hopefully you'll be able to get away with just buying a tie rod set for that side. You'll need an alignment after replacement!
