[5th Gen : 08+]: blinker and brake light issues
Old Mar 4, 2017 | 06:13 PM
Bakerid2000's Avatar
Bakerid2000
Default blinker and brake light issues
Long story.
1. fast blinking driver blinker noticed on the dash , BUT the Blinker both front and rear NOT working
2. driver brake light not working.
3. checked bulbs by moving them to the passenger side and testing them to see if they work. all bulbs worked.
4. replaced brake pedel switch, afterwards the following began: the rear drivers side blinker is WORKING but blinking fast, front drivers side blinker NOT working.
5. diver side brake light NOT working still.
6. tested emergeny 4 way hazrards, and again the back driver side light not working.
Old Mar 5, 2017 | 09:10 PM
Cougar41's Avatar
Cougar41
May or may not be data bus related but to CYA disconnect the negative battery cable for 5 minutes as a reset. The TIPM controls external light functions. Might try disconnecting the connections and inspect for any damage or corrosion. Rear light assemblies have internal circuits. Could swap the left to the right side and see if the problem follows.
