[General]: Dodge Caravan left tire rubbing during turns
Old Mar 30, 2017 | 12:21 PM
Vikingtu's Avatar
Vikingtu
Default Dodge Caravan left tire rubbing during turns
I have a 2000 Dodge Caravan. I have an issue with my Town and Country which is very similar to my Dodge and I am hoping someone here can help with the Chrysler. The issue I am having is when I make a left turn, the inside of the tire is rubbing against the frame. I have not changed tires or rims. The front end seems tight as well as the ball joints. The only thing that was changed was the right tie rod and a right axle (cv joints) but this was months ago. Nothing was changed on the left side were the issue is occurring. As mentioned this happens during tight left turns. I attached a copy of the tire rubbing against the wheel well. (Vikingtu@gmail.com)
Attached Thumbnails Dodge Caravan left tire rubbing during turns-left-tire.jpg
Old Mar 30, 2017 | 12:46 PM
Are the tires stock size?
Old Mar 31, 2017 | 09:40 AM
Vikingtu's Avatar
Vikingtu
Yes, same tires that have been on the car for years. Very odd that it would just start doing this.
Old Apr 1, 2017 | 07:32 AM
smokesxt's Avatar
smokesxt
Struts have likely settled with age, which is making it ride slightly lower. Doesn't take much to cause rubbing issues.
I've had this on both my Voyagers, 1 after lowering, the other after the struts had started wearing out.
Old Apr 1, 2017 | 10:39 PM
Vikingtu's Avatar
Vikingtu
Thanks for the post.
