[5th Gen : 08+]: 2016 Grand Caravan R/T Caliper Torque values
Old Apr 14, 2017 | 11:11 AM
underwjc's Avatar
underwjc
Cool 2016 Grand Caravan R/T Caliper Torque values
Can someone tell me what the caliper bracket bolts, caliper bolts and lug nuts torque values are for a 2016 Grand Caravan R/T van? Thanks
Old Apr 14, 2017 | 12:15 PM
Disc Brake Caliper Adapter Mounting Bolts - Front - 125 Ft. Lbs. (169 N.m.)
Disc Brake Caliper Adapter Mounting Bolts - Rear - 74 Ft. Lbs. (100 N.m.)
Disk Brake caliper guide pin bolt - 26 ft. lbs (35 N.m) on both the front and rear calipers
Lug Nuts - 100 ft. lbs
Old Oct 11, 2020 | 07:06 PM
snakedog116's Avatar
snakedog116
Thanks, this is super helpful.
Does this change for the heavy duty callipers (My car has dual pistons in the front, and a larger brake in the rear)?
Also, what is the torque spec for the bolt that connects the brake line to the calliper?
