[4th Gen : 01-07]: no start - relay?
Old May 12, 2017 | 10:05 PM
dsmblue's Avatar
dsmblue
Default no start - relay?
Our 2002 grand caravan is not starting. Just put in new battery tonight, and still would not start. When I looked under the hood, I heard a clicking noise coming from the neighborhood of the fuse/relay center. Would a bad starter relay cause a clicking/no start situation?
Old May 13, 2017 | 09:58 AM
Turning over and not starting or not turning over at all? Please clarify.
Old May 14, 2017 | 12:21 PM
dsmblue's Avatar
dsmblue
No start, no turnover. Took it to a shop and initial diagnosis is bad pcm
Old May 27, 2017 | 09:49 PM
mirageman's Avatar
mirageman
try cleaning all connections to the starter. Bet that's it.
Old May 28, 2017 | 04:00 PM
Cougar41's Avatar
Cougar41
Still broke? Remove the starter relay. Jump contacts 30 and 87 on the empty relay socket. Numbers are on bottom of relay. No keys needed. Starter should spin right away. That eliminates the starter, starter solenoid, battery and power circuit to the starter as the problem. If you can confirm the starter relay clicks when you turn the key to start, it confirms the PCM is sending the ground to the relay as designed.
