[2nd Gen : 91-95]: Coolant Leak
Old Jul 13, 2017 | 03:01 PM
JustinKC's Avatar
JustinKC
Default Coolant Leak
I have recently acquired a 1994 Dodge Grand Caravan LE that was sitting for 10 years in a garage. During the process of getting it back to a running condition I noticed that when I put coolant into the van I get a small leak from one of two lines going from the engine to the rear under the driver side.
I see where the leak is and have no doubt I can replace the lines, but I am having problems finding the parts. Does someone know where I can acquire these lines?
Thanks in advance.
Attached Thumbnails Coolant Leak-20170712_190533.jpg   Coolant Leak-20170712_190552.jpg
Old Jul 13, 2017 | 03:42 PM
Have you tried rock auto? Ebay? Those undoubtedly go to the rear heater core. Is it the metal or the rubber t hats leaking? If it the rubber hose, you can probably just buy a length of hose the same size and use new hose clamps.
Old Jul 13, 2017 | 04:07 PM
JustinKC's Avatar
JustinKC
It's leaking from the metal part of the line, close to where it join into rubber hose at the back of the van. Now that I know where the lines go I will start looking for prices.
