[5th Gen : 08+]: 2010 Left Rear Seat has no power to Window, Door or Heated Seat
Old Oct 28, 2017 | 09:22 PM
GGk's Avatar
GGk
Default 2010 Left Rear Seat has no power to Window, Door or Heated Seat
I have a 2010 and recently the left rear seat appears to have no power. The window doesn't go down, the power lock doesn't work and the heated seat has stopped. All the functions on the right side works perfect. So I assume some power feed to the left side has gone but not 100% sure or and idea where to check?
Any suggestions?
Thanks
-GGK
Old Oct 29, 2017 | 12:50 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
J-04 and M-38 are the fuses for the left side. The left door module controls them all. The heated seat switch signal also passes through that module to get to the heated seat module. The door module is probably offline and most likely problem is a broken ground wire in the sliding door track wiring harness. Very, very common issue when the vans get some age on them.
Old Oct 30, 2017 | 07:17 PM
GGk's Avatar
GGk
Hey. Thanks for your prompt reply. I checked the fuses before but rechecked and they look good. Even swapped them to double check. So it must be a ground issue. BTW. It's a 2010.
I see youre based in Nashville. Me too
Thanks
