[4th Gen : 01-07]: Insrument cluster conversion question
Old Oct 31, 2017 | 04:54 PM
lee2003caravan's Avatar
lee2003caravan
Default Insrument cluster conversion question
I have a 2003 Caravan C/V and the instrument cluster has no Tachometer. I found a 2003 Grand Caravan in a junkyard and it has the cluster with Tach.... Anybody know if this is an easy swap or:
1.) Is the wiring harness different ?
2.) does my C/V have the necessary RPM sensor installed ?
3.) Does the cluster with the Tach have to be be reprogrammed to match the original total vehicle mileage ?
Bottom line: How hard or practical is it to do this swap ? Is it even doable ?
Thanks for any input. much appreciated
Old Oct 31, 2017 | 07:50 PM
georgef's Avatar
georgef
It is plug and play. The mileage is not stored in the cluster.
Old Oct 31, 2017 | 09:30 PM
lee2003caravan
Will a cluster with Tach from a 2005 Grand Caravan be a plug/ play direct swap ? Thank you VERY much for helping me...I don't think I can live without a Tach, lol.....
Old Nov 1, 2017 | 06:59 PM
georgef's Avatar
georgef
My understanding is if it is the same model year, it will work. I don't if other years are compatible or not.
