[4th Gen : 01-07]: Blower motor not working
My front blower motor quit working. It worked one day then the next nothing.
I checked the voltage at the resistor and at the fan plug.
I have power at the resistor and ground where it needs to be .
I checked voltage at the blower and had 12 volts then when I switch the fan speed the
voltage fluctuated down to 5 volts.
I've removed the fan and resistor the fan works when 12v is put directly to it as well
As working with 12v put directly to the resistor power wire.
Only thing I can think left is a bad switch any suggestions are greatly appreciated
