[2nd Gen : 91-95]: 1994 grand caravan 3.3 l
Old Dec 18, 2017 | 03:39 PM
billy bobster's Avatar
billy bobster
Default 1994 grand caravan 3.3 l
I have a slight leak from the fuel pressure regulator. I see that there is a pressure relief valve on the fuel rail is this to attach a hose to drain it ?. can I just press this to relieve the pressure in the rail and how much fuel will generally come out ? I believe a gasket is leaking in the regulator so I need to replace it before it really leaks. whats the probability its just a gasket ? does any gasket sealer need to be used ?thanks
Old Dec 18, 2017 | 03:48 PM
Wrap a rag around it and push it. A small amount of fuel will come out. But if you have a leak, it's probably no pressure anyway.
Old Dec 18, 2017 | 04:23 PM
billy bobster
this is a very,very,very minor leak. that's why I need to fix it before it starts gushing,
