[3rd Gen : 96-00]: MAP Sensor Tesing Voltage for Signal Wire
Old Feb 2, 2018 | 03:18 PM
jackq7a's Avatar
jackq7a
Default MAP Sensor Tesing Voltage for Signal Wire
Ok, I pulled the MAP sensor to clean it yesterday because I was chasing down a bad gas mileage problem. Reinstalled and immediately the van was running worse and throwing a P108 code indicating the MAP sensor voltage was high.
I pulled led out my meter to check voltage on the disconnected harness first. I’m showing 4.90 Volts on the green wire that I assume is the signal wire. I’ve got 5.0 volts on the blackwhite wire and the ground is a ground.
From everything i can find out, the green signal wire should be 0 volts when disconnected. Or should it be this voltage?
Im wondering if I need to chase down a short.
