[5th Gen : 08+]: 2008 Dodge grand Caravan passenger sliding door cable fix
Dodge CaravanThe Dodge Caravan is the best selling mini van from Dodge. How many Dodge Caravan owners here at DodgeForum.com would agree? Discuss it now!
The cable on the passenger side of the sliding door cable came detached I reattached it the motor is running but the cable isn't moving how do I get to the motor sounds like it's behind the channel to fix it
I am guessing the motor for the cable is behind the channel....does anyone have an instructional video on re threading the cable? Can the sliding door hang off the top bracket only or should it be supporting....I'm guessing I can support it with jack stands while I disable the bottom bracket and remove the channel????
I wouldn't let it hang without some sort of support under the door and a helper to hang around and make sure it doesn't fall. The unit comes with the cable, motor and sliding door module all included ONE assembly.
Would anyone have the complete assembly part number for this lower channel???????
I just had to replace the passenger side motor assembly after the cable broke where it attached to the door. I was surprised to find it was pretty easy to replace. I only bought item #20.
Was there a video you watched to replace the cable. They want to much to replace this part there telling me it involves alot of work.. I do have the part
