[5th Gen : 08+]: 2011 Grand Caravan no crank no start no gear selection (PRND) display
No crank no start on 2011 Dodge Grand Caravan. No PRND (gear selection) display on instrument cluster. Reset instrument cluster no help. No error codes.
Anyone have this issue before? Causes? Fixes?
Thanks
Thanks
Thanks
https://www.youtube.com/watch?v=TXvytIPD-hw
Thanks
Check the alternator. It's a known issue with the Grand caravan Get rid of it if you can.
http://forum.chryslerminivan.net/sho...rnator-Failure
Update:
Turned out to be fuse M28 (PCM / Trans Feed) in fuse box.
As soon as I replaced the fuse, the car started up like normal but within a minute it smelled like burnt electronics from alternator. Battery warning light came on in dash and battery volts check with car running was at 11.6 volts.
Conclusion:
Alternator died or was about to die and tripped the fuse M28.
Fix:
Replaced fuse M28 in fuse box and replaced alternator. Now car is running as before with no issues.
Hope this helps someone down the road.
Conclusion:
Fix:
Get rid of a van because of the alternator? Yeah OK...lol
You think the vendor who makes those alternators only makes them for Chrysler?
That's not what I meant. Alternator is one of the known issues. Transmissions are failing on these vans before reaching 100k. My engine needed repair before reaching15k. Some of the vans have brakes that are under powered, you need to replace them frequently. Let me not bore you with other problems plaguing these vans.Just do a search and you'll find out for yourself.
I have no brand loyalty, believe me. But, I'll take one of these vans any day, even with the repairs.
