[5th Gen : 08+]: Best fix for antifreeze leak at rear of van
Old May 6, 2018 | 03:48 PM
tusharriv's Avatar
tusharriv
Default Best fix for antifreeze leak at rear of van
Hello. We had a puddle of antifreeze around our rear passenger wheel today on our 2012 GC. A quick look confirmed that the one hose back there has a drip coming from it where it connects back up underneath the van. I have been searching around to find the best fix for this, and a lot of the posts seem to be about older Caravans. Is the best route to cut this out and replace with rubber hose? If so, what size hose should I get? When I cut the line will antifreeze some streaming out? If this isn't the best way to do it, how should I approach this? Thanks!
Old May 6, 2018 | 05:37 PM
georgef's Avatar
georgef
Are you sure it is antifreeze?
The lines in your pictures are A/C lines, and it is normal for there to be condensation from the evaporator dripping in that area when the A/C is running.
Old May 6, 2018 | 05:42 PM
tusharriv's Avatar
tusharriv
I figured it was antifreeze because of the neon green color. It had a slight oily feel though. It seems to be coming out right at the top of that line. Thanks for your help.
Old May 7, 2018 | 09:15 PM
georgef's Avatar
georgef
The neon color is most likely fluorescent dye in the A/C system (I have heard they come from the factory with dye in the system). That is a very common location for A/C leaks.
Your coolant should be a pinkish color, and the rear lines enter the van just in front of the wheel well.
